Introdução
This guide will show you how to replace the speaker itself but before doing so, check to make sure your Bluetooth signal is not being obstructed by any objects or walls and is close enough to the speaker. Also, make sure the battery is fully charged. Both of these could be causing distorted sound on your speaker. If both of these possible causes are not true than the actual cause could have to do with your speaker in which you should replace it.
O que você precisa
Pull back the rubber corners to uncover the bottom screws.
Continue this process for all four 10 mm screws.
Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
