Ir para o conteúdo principal
BEM Mojo 2 Speaker Replacement
O que você precisa
  1. BEM Mojo 2 Speaker Replacement, Speaker Battery: passo 1, imagem 1 %32
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Replacement: passo 2, imagem 1 %32
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Replacement: passo 3, imagem 1 %32
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Replacement: passo 4, imagem 1 %32
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  6. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: passo 6, imagem 1 %32
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  7. BEM Mojo 2 Speaker Replacement: passo 7, imagem 1 %32
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  8. BEM Mojo 2 Speaker Replacement: passo 8, imagem 1 %32
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
  9. BEM Mojo 2 Speaker Replacement, Speaker: passo 9, imagem 1 %32
    • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
  10. BEM Mojo 2 Speaker Replacement: passo 10, imagem 1 %32 BEM Mojo 2 Speaker Replacement: passo 10, imagem 2 %32
    • Remove the speaker's four 10 mm base screws.
  11. BEM Mojo 2 Speaker Replacement: passo 11, imagem 1 %32 BEM Mojo 2 Speaker Replacement: passo 11, imagem 2 %32
    • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
    • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
  12. BEM Mojo 2 Speaker Replacement: passo 12, imagem 1 %32 BEM Mojo 2 Speaker Replacement: passo 12, imagem 2 %32
    • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
Conclusão
Rachel Iacoboni
Membro desde: 01/30/18
618 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S1-G1, Johnson Spring 2018 Membro de Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 351
