Ir para o conteúdo principal
BEM Mojo 2 Speaker Battery Replacement
O que você precisa
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: passo 1, imagem 1 %32
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: passo 2, imagem 1 %32
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: passo 3, imagem 1 %32
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: passo 4, imagem 1 %32
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: passo 5, imagem 1 %32
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
Conclusão
Rachel Iacoboni
Membro desde: 01/30/18
618 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S1-G1, Johnson Spring 2018 Membro de Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 527
