Ir para o conteúdo principal
BEM Mojo 2 Charging Base Battery Replacement
O que você precisa
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: passo 1, imagem 1 %32
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: passo 2, imagem 1 %32
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: passo 3, imagem 1 %32 BEM Mojo 2 Charging Base Battery Replacement: passo 3, imagem 2 %32
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: passo 4, imagem 1 %32
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
Conclusão
Rachel Iacoboni
Membro desde: 01/30/18
618 Reputação
Autoria de 5 guias
Equipe
Baylor, Team S1-G1, Johnson Spring 2018 Membro de Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 392
