Ir para o conteúdo principal
Azpen A909 Back Cover Replacement
O que você precisa
  1. Azpen A909 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Back Cover Replacement: passo 2, imagem 1 %32
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Back Cover Replacement: passo 3, imagem 1 %32
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
Conclusão
Karoly Fodor
Membro desde: 03/15/15
475 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 3-5, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-5, Duarte Spring 2015
UMASSD-DUARTE-S15S3G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 441
