Ir para o conteúdo principal
Azpen A701 Screen Replacement
O que você precisa
  1. Azpen A701 Screen Replacement, General Disassembly Prerequisite Guide: passo 1, imagem 1 %32
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Screen Replacement: passo 2, imagem 1 %32 Azpen A701 Screen Replacement: passo 2, imagem 2 %32
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Screen Replacement: passo 3, imagem 1 %32
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Screen Replacement: passo 4, imagem 1 %32
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Screen Replacement, Screen: passo 5, imagem 1 %32 Azpen A701 Screen Replacement, Screen: passo 5, imagem 2 %32 Azpen A701 Screen Replacement, Screen: passo 5, imagem 3 %32
    • Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
  6. Azpen A701 Screen Replacement: passo 6, imagem 1 %32
    • Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device).
  7. Azpen A701 Screen Replacement: passo 7, imagem 1 %32 Azpen A701 Screen Replacement: passo 7, imagem 2 %32 Azpen A701 Screen Replacement: passo 7, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the three screws that connect the motherboard to the front panel.
    • When removing the motherboard, be cautious of the gray wire connected from the motherboard to the actual device.
  8. Azpen A701 Screen Replacement: passo 8, imagem 1 %32
    • Remove the motherboard and the battery and set aside.
  9. Azpen A701 Screen Replacement: passo 9, imagem 1 %32 Azpen A701 Screen Replacement: passo 9, imagem 2 %32 Azpen A701 Screen Replacement: passo 9, imagem 3 %32
    • Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
    • Use a plastic spudger around the silver lining within the device to pry the screen off.
    • The metal screen assembly is two pieces. When removing the screen, make sure to pry off both pieces at once.
  10. Azpen A701 Screen Replacement: passo 10, imagem 1 %32
    • Replace the broken screen and reverse the steps to re-assemble the device.
Conclusão
Uma outra pessoa concluiu este guia.
Michael
Membro desde: 03/11/15
568 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 724
