Ir para o conteúdo principal
Axess TA2513-10WT Side Button Replacement
O que você precisa
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: passo 1, imagem 1 %32
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: passo 2, imagem 1 %32 Axess TA2513-10WT Side Button Replacement: passo 2, imagem 2 %32 Axess TA2513-10WT Side Button Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: passo 3, imagem 1 %32
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: passo 4, imagem 1 %32
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: passo 5, imagem 1 %32 Axess TA2513-10WT Side Button Replacement, Buttons: passo 5, imagem 2 %32
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: passo 6, imagem 1 %32 Axess TA2513-10WT Side Button Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: passo 7, imagem 1 %32 Axess TA2513-10WT Side Button Replacement: passo 7, imagem 2 %32
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: passo 8, imagem 1 %32 Axess TA2513-10WT Side Button Replacement: passo 8, imagem 2 %32 Axess TA2513-10WT Side Button Replacement: passo 8, imagem 3 %32
    • Remove the individual buttons with tweezers.
Conclusão
Lori Scott
Membro desde: 03/24/15
101 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 6-3, Shaver Spring 2015 Membro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 247
