Ir para o conteúdo principal
Axess TA2513-10WT Battery Replacement
O que você precisa
  1. Axess TA2513-10WT Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Battery Replacement: passo 2, imagem 1 %32 Axess TA2513-10WT Battery Replacement: passo 2, imagem 2 %32 Axess TA2513-10WT Battery Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Battery Replacement: passo 3, imagem 1 %32
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Battery Replacement: passo 4, imagem 1 %32
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Battery Replacement, Battery: passo 5, imagem 1 %32
    • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
  6. Axess TA2513-10WT Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery up with your hands to ensure complete detachment from the screen.
  7. Axess TA2513-10WT Battery Replacement: passo 7, imagem 1 %32
    • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
  8. Axess TA2513-10WT Battery Replacement: passo 8, imagem 1 %32
    • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
  9. Axess TA2513-10WT Battery Replacement: passo 9, imagem 1 %32
    • Remove the red wire from the node labeled "B+"
  10. Axess TA2513-10WT Battery Replacement: passo 10, imagem 1 %32
    • Using the same process as the red wire, detach the black wire from the node labeled "B-".
  11. Axess TA2513-10WT Battery Replacement: passo 11, imagem 1 %32
    • The battery should now be separated from both the screen and circuit board
Conclusão
Steven Kavanagh
Membro desde: 03/24/15
301 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 6-3, Shaver Spring 2015 Membro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 290
