Ir para o conteúdo principal
Axe Empire 2.0 OLED Board Replacement
O que você precisa
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: passo 1, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement, OLED Board: passo 1, imagem 2 %32
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: passo 2, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 2, imagem 2 %32 Axe Empire 2.0 OLED Board Replacement: passo 2, imagem 3 %32
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: passo 3, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 3, imagem 2 %32 Axe Empire 2.0 OLED Board Replacement: passo 3, imagem 3 %32
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: passo 4, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 4, imagem 2 %32
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: passo 5, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 5, imagem 2 %32
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: passo 6, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 6, imagem 2 %32 Axe Empire 2.0 OLED Board Replacement: passo 6, imagem 3 %32
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: passo 7, imagem 1 %32 Axe Empire 2.0 OLED Board Replacement: passo 7, imagem 2 %32
    • Disconnect the battery from the OLED board.
Conclusão
Christopher Ramos
Membro desde: 10/05/21
345 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 199
