Introdução
This guide will demonstrate how to replace the IR LED lightboard for your AvertX HD810 dome camera. This guide has one prerequisite guide labeled, 'Clear Dome Camera'. The two tools required for this guide are the T10 Torx security bit screwdriver and the PH1 (Phillips Head) screwdriver. It's important to that the camera turned off, and optimally, unplugged for this procedure.
O que você precisa
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Use the PH1 screwdriver to remove or loosen both 10mm screws on either side of the inner protective lens cover. This will loosen both the cover and the IR LED lightboard.
Uma outra pessoa concluiu este guia.
