Introdução
Users will gain knowledge in wiring environmental sensor nodes. This includes stripping, splicing, and crimping wires to ensure connections stay in place to withstand time and the elements.
Grabbing the white connector, pull the battery connector from the solar charge controller
Disconnect the plugs for the autosampler battery
Be sure to also disconnect the connector that plugs into the battery port of the sampler
Unscrew conduit and release to open up more space to work with
Unscrew existing wires using 260 / 1.5 x 40 flathead screwdriver
Cut and strip each wire
Use a wire cutter to trim existing wire and remove old copper strands
Strip the 18-gage wire about 1/4"
Cut 20-gage wire approximately 6 inches. Repeat until you have five new wires.
Strip each wire approximately 1/4". Do this on both ends of each wire
On only one side of each wire, crimp on a wire ferrule
Crimp a splice connector to the other end of the wire
Place the other end of the splice connector over 18-gage wire. Then crimp to secure the connection
Although these wires are in pairs, strip each wire individually, approximately 1/4"
Pull the wires through
Reattach the conduit to provide strain relief and prevent wires from being dragged down
Insert the wires and screw down using 260 / 1.5 x 40 flathead screwdriver until tight
The battery connectors go in the fifth and sixth positions from the left
Using a 260/2.5 x 50 flathead screwdriver, insert each wire into the respective position shown
Using velcro, re-secure the relay board to the side of the enclosure
Using velcro, attach the battery to the inside of the enclosure door
In case the wiring of an ultrasonic sensor comes loose, here is the wiring.
First reconnect the batteries.
Secure solar charge controller to the side of the enclosure using velcro
Plug in the solar panel last
Now we can close and lock up the enclosure. The node is ready to test and confirm everything is working,
