Ir para o conteúdo principal
Autosampler Configuration (For Old & New Versions)
O que você precisa
  1. Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: passo 1, imagem 1 %32 Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: passo 1, imagem 2 %32
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration  (For Old & New Versions), Configuring "set clock".: passo 2, imagem 1 %32
    • The first option for configuring is "SET CLOCK"
    • 3. Press "ENTER/PROGRAM" to "SET CLOCK". Use the numeric keys to set the time and date. You can use the arrows to move. When finished. Press "ENTER/PROGRAM" button.
  3. Autosampler Configuration  (For Old & New Versions), Configuring "bottles and sizes".: passo 3, imagem 1 %32
    • 4. Press "ENTER/PROGRAM" to configure "BOTTLES AND SIZES".
    • Use arrows to select "PORTABLE" sampler. Press "ENTER/PROGRAM" to configure bottles and sizes.
    • Use arrows to select "24" botles. Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "1000" mL for the "BOTTLE VOLUME". Press "ENTER/PROGRAM" button.
  4. Autosampler Configuration  (For Old & New Versions), Configuring "suction line".: passo 4, imagem 1 %32
    • 5. Press "ENTER/PROGRAM" to configure "SUCTION LINE".
    • Use arrow to select "3/8" inch for "SUCTION LINE I.D." Press "ENTER/PROGRAM" button.
    • Use arrow to select "VINYL" for "SUCTION LINE" type. Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "25" feet for "SUCTION LINE LENGTH". Press "ENTER/PROGRAM" button.
    • The suction line length may change based on location and should be measured!
  5. Autosampler Configuration  (For Old & New Versions), Configuring "liquid detector".: passo 5, imagem 1 %32
    • 6. Press "ENTER/PROGRAM" button to configure "LIQUID DETECTOR".
    • Use arrows to select "ENABLE" "LIQUID DECTOR". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "3" "RINSE CYCLES." Press "ENTER/PROGRAM" button.
    • Screen will read "ENTER HEAD MANUALLY?" Use arrows to select "NO". Press "ENTER/PROGRAM" button.
    • Screen will read "RETRY UP TO X TIMES WHEN SAMPLING?" Use numeric keys to enter "3". Press "ENTER/PROGRAM" button.
  6. Autosampler Configuration  (For Old & New Versions), Configuring "programming mode".: passo 6, imagem 1 %32
    • 7. Press "ENTER/PROGRAM" to configure "PROGRAMMING MODE".
    • Use arrows to select "BASIC" mode. Press "ENTER/PROGRAM" button.
  7. Autosampler Configuration  (For Old & New Versions), Configuring "calibrate sampler".: passo 7, imagem 1 %32
    • 8. Press "ENTER/PROGRAM" to configure "CALIBRATE SAMPLER".
    • Use arrows to select "DISABLE" "CALIBRATE SAMPLER". Press "ENTER/PROGRAM" button.
  8. Autosampler Configuration  (For Old & New Versions), Configuring "start time delay".: passo 8, imagem 1 %32
    • 9. Press "ENTER/PROGRAM" to configure "START TIME DELAY". Press "ENTER/PROGRAM" button.
    • Screen will read "X MINUTE DELAY TO START." Use numeric keys to enter "0" minutes. Press "ENTER/PROGRAM" button.
  9. Autosampler Configuration  (For Old & New Versions), Configuring "enabling pin".: passo 9, imagem 1 %32
    • 10. Press "ENTER/PROGRAM" to configure "ENABLE PIN". Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "MASTER/SLAVE MODE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "SAMPLE UPON DISABLE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "SAMPLE UPON ENABLE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "RESET SAMPLE INTERVAL?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "INHIBIT COUNTDOWN?" Press "ENTER/PROGRAM" button.
  10. Autosampler Configuration  (For Old & New Versions), Configuring "event mark".: passo 10, imagem 1 %32
    • 11. Press "ENTER/PROGRAM" to configure "EVENT MARK". Press "ENTER/PROGRAM" button.
    • Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
  11. Autosampler Configuration  (For Old & New Versions), Configuring "purge counts".: passo 11, imagem 1 %32
    • 12. Press "ENTER/PROGRAM" to configure "PURGE COUNTS". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XX" for "PRE-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XX" for "POST-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
  12. Autosampler Configuration  (For Old & New Versions), Configuring "tubing life".: passo 12, imagem 1 %32
    • 12. Press "ENTER/PROGRAM" to configure "TUBING LIFE". Press "ENTER/PROGRAM" button.
    • Screen will read "X PUMP COUNTS, WARNING AT XXX000". Press "ENTER/PROGRAM" button.
    • Use arrows to select "NO" for "RESET PUMP COUNTER?". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XXX000" for "PUMP COUNTS TO WARNING". Press "ENTER/PROGRAM" button.
  13. Autosampler Configuration  (For Old & New Versions), Configuring "program lock".: passo 13, imagem 1 %32
    • 13. Press "ENTER/PROGRAM" to configure "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
    • Use arrows to select "DISABLE" "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
  14. Autosampler Configuration  (For Old & New Versions), Configuring "sampler ID".: passo 14, imagem 1 %32
    • 15. The next configuration option is "SAMPLER ID". Skip this configuration step by using the arrows.
  15. Autosampler Configuration  (For Old & New Versions), Configuring "run diagonostics".: passo 15, imagem 1 %32
    • 16. The next configuration option is "RUN DIAGNOSTICS". Skip this configuration step by using the arrows.
Linha de Chegada
Brooke Mason
Membro desde: 05/29/19
2.928 Reputação
Autoria de 17 guias
Equipe
Open-Storm Membro de Open-Storm
Community
Membros da 14
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 196
