Introdução
This guide will help teach you how to remove and replace the drum of the gun that holds your darts. This require splitting the gun into two halves and requires a #00 Phillips head screwdriver, but is otherwise fairly simple. Just follow the steps and get your gun back into fighting shape!
O que você precisa
Locate the orange slider on the front side of the gun.
Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
3 outras pessoas executaram este guia.
