Ir para o conteúdo principal
Automatic Tommy 20 Ammo Drum Replacement
O que você precisa
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: passo 1, imagem 1 %32 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: passo 1, imagem 2 %32
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: passo 2, imagem 1 %32 Automatic Tommy 20 Ammo Drum Replacement: passo 2, imagem 2 %32 Automatic Tommy 20 Ammo Drum Replacement: passo 2, imagem 3 %32
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: passo 3, imagem 1 %32 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: passo 3, imagem 2 %32 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: passo 3, imagem 3 %32
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: passo 4, imagem 1 %32
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
Conclusão
3 outras pessoas executaram este guia.
Moira Foster
Membro desde: 10/09/14
419 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-22, Maness Fall 2014 Membro de Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 794
