Introdução
Here you will learn to remove the bushing of the dart gun's ammo drum. It is relatively hard to get at and requires disassembling the gun a fair degree and therefore requires a Phillips #00 screwdriver. This is one of the trickier guides for this device, so have fun and be careful!
O que você precisa
Locate the orange slider on the front side of the gun.
Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
Remove the bushing by simply pulling it away from the plastic.
Uma outra pessoa concluiu este guia.
