Ir para o conteúdo principal
Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly
O que você precisa
  1. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: passo 1, imagem 1 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: passo 1, imagem 2 %32
    • Using a T10 screwdriver, remove the eight screws located on the rear panel of the device (4 towards the bottom, and 4 towards the top).
  2. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 2, imagem 1 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 2, imagem 2 %32
    • Unscrew one PH2 screw.
    • Use a spudger or a thin curved tool such as a dental pick to remove the bean hopper of the burr grinder.
    • Remove the grind selector by pulling the dial directly away from the machine which will remove it from the housing.
  3. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 3, imagem 1 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 3, imagem 2 %32
    • The Hex screw must be unscrewed in the clockwise direction. Failure to do so could result in damage of the grinding mechanism.
    • Unscrew the one 4mm Hex in a clockwise fashion and remove the black plastic cover over the burrset.
    • Remove the black plastic cover over the burr set.
    • The burr set should not be completely visible.
  4. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 4, imagem 1 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 4, imagem 2 %32
    • Unscrew the three PH2 screws.
    • Slide the top panel backwards to remove it.
  5. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, imagem 1 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, imagem 2 %32 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: passo 5, imagem 3 %32
    • Now you should have access to the internal components of the appliance.
Conclusão
4 outras pessoas executaram este guia.
Egas
Membro desde: 09/20/10
181 Reputação
Autoria de 1 guia
Equipe
Zi repair Membro de Zi repair
Business
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 42
Últimos 30 dias: 177
Duração total: 3,339
