Ir para o conteúdo principal
August Smart Lock Speaker Replacement
O que você precisa
  1. August Smart Lock Speaker Replacement, Speaker: passo 1, imagem 1 %32 August Smart Lock Speaker Replacement, Speaker: passo 1, imagem 2 %32 August Smart Lock Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Speaker Replacement: passo 2, imagem 1 %32 August Smart Lock Speaker Replacement: passo 2, imagem 2 %32 August Smart Lock Speaker Replacement: passo 2, imagem 3 %32
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
  3. August Smart Lock Speaker Replacement: passo 3, imagem 1 %32 August Smart Lock Speaker Replacement: passo 3, imagem 2 %32 August Smart Lock Speaker Replacement: passo 3, imagem 3 %32
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
  4. August Smart Lock Speaker Replacement: passo 4, imagem 1 %32 August Smart Lock Speaker Replacement: passo 4, imagem 2 %32
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
Conclusão
Uma outra pessoa concluiu este guia.
William Fink
Membro desde: 09/26/17
766 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S11-G6, Passmore Fall 2017 Membro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,443
