Ir para o conteúdo principal
Audiovox Tri-mode CDM-9000 Keypad Replacement
O que você precisa
  1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: passo 1, imagem 1 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: passo 1, imagem 2 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: passo 1, imagem 3 %32
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 2, imagem 1 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 2, imagem 2 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 2, imagem 3 %32
    • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
    • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
  3. Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 3, imagem 1 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 3, imagem 2 %32 Audiovox Tri-mode CDM-9000 Keypad Replacement: passo 3, imagem 3 %32
    • Once you have the phone apart simply remove the key pad and replace it with the new one.
    • Don't forget to put the screws back in. Place the battery back on the phone.
    • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
Conclusão
Summer Sines
Membro desde: 09/27/14
406 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 487
