Ir para o conteúdo principal
Audiovox Tri-mode CDM-9000 Battery Replacement
  1. Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, imagem 1 %32 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, imagem 2 %32 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: passo 1, imagem 3 %32
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: passo 2, imagem 1 %32 Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: passo 2, imagem 2 %32
    • Once the back piece is released, simply lift the battery up and away from the phone.
    • Replace the battery by placing the bottom part of the battery in first and push down. You will hear a loud click sound when the battery is secure.
Conclusão
Uma outra pessoa concluiu este guia.
Summer Sines
Membro desde: 09/27/14
406 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 343
