Introdução
This is an in-depth guide on how to replace the camera in your Audiovox T752. The guide includes step-by-step instructions and pictures to help you through the process.
O que você precisa
Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
NOTE: some force will need to be used to remove the cover. Avoid excessive force.
Remove the pink and aluminum protective cover. Be sure to also remove any tape holding it in place.
