Ir para o conteúdo principal
Audiovox CDM-8910 Keyboard Replacement
O que você precisa
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: passo 1, imagem 1 %32
    • Locate the antenna (shown in red box) at the top of the phone when closed.
    Pergunte ao FixBot
    Comentar
  2. Audiovox CDM-8910 Keyboard Replacement: passo 2, imagem 1 %32
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
    Pergunte ao FixBot
    Comentar
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: passo 3, imagem 1 %32
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
    Pergunte ao FixBot
    Comentar
  4. Audiovox CDM-8910 Keyboard Replacement: passo 4, imagem 1 %32
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
    Pergunte ao FixBot
    Comentar
  5. Audiovox CDM-8910 Keyboard Replacement: passo 5, imagem 1 %32
    • The back of the phone will look like this when the battery is correctly removed.
    Pergunte ao FixBot
    Comentar
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: passo 6, imagem 1 %32
    • Peel the rubber indicated toward the top of the phone
    Pergunte ao FixBot
    Comentar
  7. Audiovox CDM-8910 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove the screw that sits underneath the rubber covering.
    Pergunte ao FixBot
    Comentar
  8. Audiovox CDM-8910 Keyboard Replacement: passo 8, imagem 1 %32
    • Remove the five (5) total screws using a Philips head screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Audiovox CDM-8910 Keyboard Replacement: passo 9, imagem 1 %32
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
    Pergunte ao FixBot
    Comentar
  10. Audiovox CDM-8910 Keyboard Replacement: passo 10, imagem 1 %32
    • The back case should now be completely removed and the motherboard will be visible.
    Pergunte ao FixBot
    Comentar
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: passo 11, imagem 1 %32 Audiovox CDM-8910 Keyboard Replacement, Motherboard: passo 11, imagem 2 %32 Audiovox CDM-8910 Keyboard Replacement, Motherboard: passo 11, imagem 3 %32
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
    Pergunte ao FixBot
    Comentar
  12. Audiovox CDM-8910 Keyboard Replacement: passo 12, imagem 1 %32
    • Using a spudger, lift the motherboard out of the phone case as pictured.
    Pergunte ao FixBot
    Comentar
  13. Audiovox CDM-8910 Keyboard Replacement: passo 13, imagem 1 %32
    • The motherboard should now be completely removed from the phone.
    Pergunte ao FixBot
    Comentar
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: passo 14, imagem 1 %32
    • Once the motherboard has been removed, peel the keyboard as pictured.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 3-24, Regan Fall 2010 Membro de Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 1,739
