Ir para o conteúdo principal
Audiovox CDM-8900 Main LCD Screen Replacement
O que você precisa
  1. Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: passo 1, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement, Main LCD Screen: passo 1, imagem 2 %32
    • Remove four screw covers using the spudger.
    • Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
  2. Audiovox CDM-8900 Main LCD Screen Replacement: passo 2, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the four Phillips #00 screws.
    • Tweezers may be useful for removing loosened screws.
  3. Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, imagem 2 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 3, imagem 3 %32
    • The small electronic components inside the phone are fragile; take care not to damage them when completing this step.
    • Wedge one of the plastic opening tools under the phone cover near the hinge.
    • Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
    • Detach the phone cover from the phone's base.
  4. Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, imagem 2 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 4, imagem 3 %32
    • Slide out the two metal braces located along the sides of the LCD screen.
    • Carefully peel back the tape from both sides of the copper frame.
  5. Audiovox CDM-8900 Main LCD Screen Replacement: passo 5, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 5, imagem 2 %32
    • Do not detach or tear any wires when completing this step.
    • Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
    • The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
  6. Audiovox CDM-8900 Main LCD Screen Replacement: passo 6, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 6, imagem 2 %32
    • The copper frame is attached to the phone at the hinge. Do not tear the frame.
    • Gently lift the copper frame surrounding the LCD screen.
  7. Audiovox CDM-8900 Main LCD Screen Replacement: passo 7, imagem 1 %32 Audiovox CDM-8900 Main LCD Screen Replacement: passo 7, imagem 2 %32
    • With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
Conclusão
Aaron Shaw
Membro desde: 04/15/10
159 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 28-31, Regan Spring 2010 Membro de Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 4,129
