Ir para o conteúdo principal
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
O que você precisa
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: passo 1, imagem 1 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: passo 1, imagem 2 %32
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 2, imagem 1 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 2, imagem 2 %32
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 3, imagem 1 %32
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 4, imagem 1 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 4, imagem 2 %32
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 5, imagem 1 %32
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, imagem 1 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, imagem 2 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 6, imagem 3 %32
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 7, imagem 1 %32
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 8, imagem 1 %32
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 9, imagem 1 %32
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, imagem 1 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, imagem 2 %32 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: passo 10, imagem 3 %32
    • Test the function by spinning the platter and put the rubber mat into place.
Conclusão
Uma outra pessoa concluiu este guia.
Zonghao Li
Membro desde: 01/20/21
208 Reputação
Autoria de 1 guia
Um comentário
Thank you so much!
Joe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 149
Últimos 30 dias: 687
Duração total: 7,928
