Ir para o conteúdo principal
Audio Technica ATH-M50 Ear pads Replacement
  1. Audio Technica ATH-M50 Ear pads Replacement, Preparing Ear pads for removal: passo 1, imagem 1 %32
    • Unfold the headphones and lay down flat with the pads facing up
    • Once facing up ,tuck your fingers under the edge of the inside of the ear pad and carefully pull up until the ear pad starts to come off
  2. Audio Technica ATH-M50 Ear pads Replacement, Removing the ear pad: passo 2, imagem 1 %32
    • After creating a gap continue to lift the ear pad off until fully removed
    • For reinstalling the ear pads use the same techniques for a easy installation
    • On older headphones the foam sponge part of the ear pad can deteriorate,it is recommended that if there is any leftover foam that it is remove to the best of your ability to improve the longevity of the headphone,the drivers are delicate please be careful:-)
    • Congratulations you have now removed your M50’s ear pads:-)
Conclusão
HelloMacOS
Membro desde: 01/24/22
26.006 Reputação
Autoria de 11 guias
Equipe
Repair is War on Entropy Membro de Repair is War on Entropy
Community
Membros da 25
Autoria de 1.154 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 36
Duração total: 960
