Ir para o conteúdo principal
Audio Technica ATH-AD500 Right Headphone Cable Replacement
O que você precisa
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: passo 1, imagem 1 %32
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - Responder
    How to install the earpads
    rangaranju - Responder
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 2, imagem 1 %32
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 3, imagem 1 %32
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: passo 4, imagem 1 %32 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: passo 4, imagem 2 %32
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference Como soldar e dessoldar contatos.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 5, imagem 1 %32 Audio Technica ATH-AD500 Right Headphone Cable Replacement: passo 5, imagem 2 %32
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference Como soldar e dessoldar contatos.
Conclusão
3 outras pessoas executaram este guia.
Melanie Reis
Membro desde: 01/11/13
227 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-19, Forte Winter 2013 Membro de Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
Membros da 6
Autoria de 17 guias
3 comentários
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - Responder
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - Responder
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 4,528
