Ir para o conteúdo principal
Atmega328P Microcontroller Replacement for Arduino Board
O que você precisa
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: passo 1, imagem 1 %32
    • Place the Arduino UNO R3 board on a flat clean surface.
    Pergunte ao FixBot
    Comentar
  2. Atmega328P Microcontroller Replacement for Arduino Board: passo 2, imagem 1 %32 Atmega328P Microcontroller Replacement for Arduino Board: passo 2, imagem 2 %32
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
    Pergunte ao FixBot
    Comentar
  3. Atmega328P Microcontroller Replacement for Arduino Board: passo 3, imagem 1 %32 Atmega328P Microcontroller Replacement for Arduino Board: passo 3, imagem 2 %32
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
    Pergunte ao FixBot
    Comentar
  4. Atmega328P Microcontroller Replacement for Arduino Board: passo 4, imagem 1 %32 Atmega328P Microcontroller Replacement for Arduino Board: passo 4, imagem 2 %32 Atmega328P Microcontroller Replacement for Arduino Board: passo 4, imagem 3 %32
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
    Pergunte ao FixBot
    Comentar
  5. Atmega328P Microcontroller Replacement for Arduino Board: passo 5, imagem 1 %32
    • Remove replacement microcontroller out of packaging.
    Pergunte ao FixBot
    Comentar
  6. Atmega328P Microcontroller Replacement for Arduino Board: passo 6, imagem 1 %32
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
    Pergunte ao FixBot
    Comentar
  7. Atmega328P Microcontroller Replacement for Arduino Board: passo 7, imagem 1 %32 Atmega328P Microcontroller Replacement for Arduino Board: passo 7, imagem 2 %32
    • Gently press the microcontroller into the dip socket
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
UC Davis, Team 5-5, Morris Winter 2023 Membro de UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 60
Ao todo: 1,383
