Ir para o conteúdo principal
Atari Flashback 2 Reset and Select Button Replacement
O que você precisa
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 1 %32 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 2 %32 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: passo 1, imagem 3 %32
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 1 %32 Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 2 %32 Atari Flashback 2 Reset and Select Button Replacement: passo 2, imagem 3 %32
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Conclusão
Gabriel Robinson
Membro desde: 09/17/18
85 Reputação
Autoria de 1 guia
Equipe
2Comentários do guia
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Responder
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,015
