Ir para o conteúdo principal
Atari 5200 Controller Side Buttons Replacement
O que você precisa
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: passo 1, imagem 1 %32 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: passo 1, imagem 2 %32 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: passo 1, imagem 3 %32
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    Pergunte ao FixBot
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: passo 2, imagem 1 %32 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: passo 2, imagem 2 %32
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
    Pergunte ao FixBot
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: passo 3, imagem 1 %32 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: passo 3, imagem 2 %32
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    Pergunte ao FixBot
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: passo 4, imagem 1 %32 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: passo 4, imagem 2 %32
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
    Pergunte ao FixBot
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: passo 5, imagem 1 %32 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: passo 5, imagem 2 %32 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: passo 5, imagem 3 %32
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
Alan Abelson
Membro desde: 09/26/14
233 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 51
Ao todo: 1,389
