Introdução
How to disassemble the Atari 2600 Junior to remove the circuit board.
O que você precisa
Use a metal or heavy duty spudger to unhook the 3 plastic clips holding the front of the case together.
Be careful not to break the plastic clips
While unhooking the center hook use another spudger to run along the top and bottom casing. This helps to get the clip lose.
Be careful not to pull the case apart quickly, there is a ribbon that is attached to the top and bottom.
Detach the ribbon from the circuit board by gently pulling ribbon out from clip.
There are 2 clips holding the circuit board in place.
Using a metal or heavy duty spudger release the clip on the left side.
Remove the circuit board.
7 outras pessoas executaram este guia.
