Ir para o conteúdo principal
Asus Zenfone 4 Max SIM Card Replacement
O que você precisa
  1. Asus Zenfone 4 Max SIM Card Replacement, SIM Card: passo 1, imagem 1 %32
    • Locate the SIM tray on the left edge of the phone.
    • There is a small hole on the outside of the SIM tray that will be used for opening the tray.
  2. Asus Zenfone 4 Max SIM Card Replacement: passo 2, imagem 1 %32 Asus Zenfone 4 Max SIM Card Replacement: passo 2, imagem 2 %32
    • Insert a SIM card eject tool into the hole.
    • Press until the SIM tray pops out slightly from the phone.
    • Be careful not to force any object to fit into the tray's opening hole. The object should be thin enough to fit directly into the hole.
  3. Asus Zenfone 4 Max SIM Card Replacement: passo 3, imagem 1 %32 Asus Zenfone 4 Max SIM Card Replacement: passo 3, imagem 2 %32
    • Once the SIM tray has been opened, gently pull the tray completely out of the phone.
    • Lift the old SIM card out of the tray with your fingers or flip the tray upside down to make the card fall out.
  4. Asus Zenfone 4 Max SIM Card Replacement: passo 4, imagem 1 %32
    • Finally, replace the old card with the new SIM card and close the SIM tray.
Conclusão
To reassemble your device, place the SIM tray back into the tray slot
Maegan West
Membro desde: 10/02/18
839 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Duração total: 2,151
