Ir para o conteúdo principal
Asus Zenfone 4 Max Charging Port Replacement
O que você precisa
  1. Asus Zenfone 4 Max Charging Port Replacement, Battery: passo 1, imagem 1 %32 Asus Zenfone 4 Max Charging Port Replacement, Battery: passo 1, imagem 2 %32
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Charging Port Replacement: passo 2, imagem 1 %32
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Charging Port Replacement: passo 3, imagem 1 %32 Asus Zenfone 4 Max Charging Port Replacement: passo 3, imagem 2 %32 Asus Zenfone 4 Max Charging Port Replacement: passo 3, imagem 3 %32
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Charging Port Replacement: passo 4, imagem 1 %32
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Charging Port Replacement: passo 5, imagem 1 %32 Asus Zenfone 4 Max Charging Port Replacement: passo 5, imagem 2 %32
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Charging Port Replacement: passo 6, imagem 1 %32
    • Remove the battery and replace it with the new battery.
  7. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: passo 7, imagem 1 %32 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: passo 7, imagem 2 %32 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: passo 7, imagem 3 %32
    • Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
    • Lift the panel along with the charging port out the device and replace with the new charging port.
Conclusão
3 outras pessoas executaram este guia.
Maegan West
Membro desde: 10/02/18
839 Reputação
Autoria de 4 guias
Equipe
2 comentários
repair microfone asus zenfone 4 selfie pro please
John Wesley - Responder
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
Max Orwell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 3,203
