Ir para o conteúdo principal
Asus Zenfone 4 Max Camera Replacement
O que você precisa
  1. Asus Zenfone 4 Max Camera Replacement, Camera: passo 1, imagem 1 %32
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: passo 2, imagem 1 %32
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: passo 3, imagem 1 %32 Asus Zenfone 4 Max Camera Replacement: passo 3, imagem 2 %32
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: passo 4, imagem 1 %32 Asus Zenfone 4 Max Camera Replacement: passo 4, imagem 2 %32 Asus Zenfone 4 Max Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Conclusão
Maegan West
Membro desde: 10/02/18
839 Reputação
Autoria de 4 guias
Equipe
2 comentários
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Responder
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,981
