Ir para o conteúdo principal
Asus Zenfone 3 Zoom Battery Replacement
O que você precisa
  1. Asus Zenfone 3 Zoom Battery Replacement, Battery: passo 1, imagem 1 %32 Asus Zenfone 3 Zoom Battery Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Asus Zenfone 3 Zoom Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Asus Zenfone 3 Zoom Battery Replacement: passo 3, imagem 1 %32 Asus Zenfone 3 Zoom Battery Replacement: passo 3, imagem 2 %32
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Asus Zenfone 3 Zoom Battery Replacement: passo 4, imagem 1 %32
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Asus Zenfone 3 Zoom Battery Replacement: passo 5, imagem 1 %32
    • Peel back the silver tape.
  6. Asus Zenfone 3 Zoom Battery Replacement: passo 6, imagem 1 %32
    • Disconnect the battery connections.
  7. Asus Zenfone 3 Zoom Battery Replacement: passo 7, imagem 1 %32
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
Conclusão
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 3,818
