Ir para o conteúdo principal
Asus Zenbook UX32VD GPU Fan Replacement
O que você precisa
  1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: passo 1, imagem 1 %32 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: passo 1, imagem 2 %32 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    T5 Torx Screwdriver
    $9.99
    Comprar
  2. Asus Zenbook UX32VD GPU Fan Replacement: passo 2, imagem 1 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 2, imagem 2 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 2, imagem 3 %32
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD GPU Fan Replacement, Fan: passo 3, imagem 1 %32 Asus Zenbook UX32VD GPU Fan Replacement, Fan: passo 3, imagem 2 %32 Asus Zenbook UX32VD GPU Fan Replacement, Fan: passo 3, imagem 3 %32
    Spudger
    $2.99
    Comprar
    • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
    • Be sure to pry up on the hinged retaining flap, not the connector itself.
    • Remove the metallic ribbon cable from the connector .
    • No force is needed to remove or insert the cable.
  4. Asus Zenbook UX32VD GPU Fan Replacement: passo 4, imagem 1 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 4, imagem 2 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 4, imagem 3 %32
    Phillips #0 Screwdriver
    $5.49
    Comprar
  5. Asus Zenbook UX32VD GPU Fan Replacement: passo 5, imagem 1 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 5, imagem 2 %32 Asus Zenbook UX32VD GPU Fan Replacement: passo 5, imagem 3 %32
    • Unplug the bundled cable connector.
    • Move the fan as shown in the first picture to better access the connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD GPU Fan Replacement: passo 6, imagem 1 %32
    • Remove the fan completely.
Conclusão
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 2,195
