Ir para o conteúdo principal
Asus Zenbook UX32VD HD Web Camera Replacement
O que você precisa
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: passo 1, imagem 1 %32
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, imagem 1 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, imagem 2 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Metal Spudger Set
    $7.99
    Comprar
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, imagem 1 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, imagem 2 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 3, imagem 3 %32
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 4, imagem 1 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 4, imagem 2 %32
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, imagem 1 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, imagem 2 %32 Asus Zenbook UX32VD  HD Web Camera Replacement: passo 5, imagem 3 %32
    Spudger
    $2.99
    Comprar
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
Conclusão
Michael Remmel
Membro desde: 09/17/15
718 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
Membros da 4
Autoria de 6 guias
2 comentários
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Responder
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,897
