Ir para o conteúdo principal
Asus Zenbook UX31E Speaker Replacement
O que você precisa
  1. Asus Zenbook UX31E Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Speaker Replacement: passo 2, imagem 1 %32
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  4. Asus Zenbook UX31E Speaker Replacement: passo 4, imagem 1 %32 Asus Zenbook UX31E Speaker Replacement: passo 4, imagem 2 %32
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  5. Asus Zenbook UX31E Speaker Replacement: passo 5, imagem 1 %32 Asus Zenbook UX31E Speaker Replacement: passo 5, imagem 2 %32
    • Disconnect the sound cable from the motherboard.
  6. Asus Zenbook UX31E Speaker Replacement: passo 6, imagem 1 %32 Asus Zenbook UX31E Speaker Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, pry open the speaker component from the computer.
Conclusão
Equipe
UW Tacoma, Team 1-2, Rose Winter 2017 Membro de UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 2,706
