O que você precisa
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Disconnect the ribbon between the IO and the motherboard on both sides.
Quase terminado!
Conclusão
Can you tell me what size these screws are? I need to replace two.
Elliot Lozano - Responder
I don’t know, but you can search with product code: VISTORXUX31E
See also: https://en.accessoires-asus.com/torx-scr...|l
Davide Bortot -
