Ir para o conteúdo principal
Asus Zenbook UX31E Fan Replacement
O que você precisa
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: passo 2, imagem 1 %32
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: passo 3, imagem 1 %32 Asus Zenbook UX31E Fan Replacement, Fan: passo 3, imagem 2 %32
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: passo 4, imagem 1 %32
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: passo 5, imagem 1 %32 Asus Zenbook UX31E Fan Replacement: passo 5, imagem 2 %32
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: passo 6, imagem 1 %32 Asus Zenbook UX31E Fan Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Conclusão
Sinh
Membro desde: 02/01/17
101 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-2, Rose Winter 2017 Membro de UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
Membros da 4
Autoria de 9 guias
Um comentário
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,715
