O que você precisa
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
5 outras pessoas executaram este guia.
2 comentários
Thanks for the easy to understand guide. Cheers!
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
Can you tell me what size these screws are? I need to replace two.
Elliot Lozano - Responder
I don’t know, but you can search with product code: VISTORXUX31E
See also: https://en.accessoires-asus.com/torx-scr...|l
Davide Bortot -
