Ir para o conteúdo principal
Asus Zenbook UX31E Battery Replacement
O que você precisa
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Battery Replacement: passo 2, imagem 1 %32
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: passo 3, imagem 1 %32 Asus Zenbook UX31E Battery Replacement, Battery: passo 3, imagem 2 %32
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: passo 4, imagem 1 %32 Asus Zenbook UX31E Battery Replacement: passo 4, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: passo 5, imagem 1 %32 Asus Zenbook UX31E Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
Conclusão
5 outras pessoas executaram este guia.
Hersi Dahir
Membro desde: 02/02/17
203 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-2, Rose Winter 2017 Membro de UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
Membros da 4
Autoria de 9 guias
2 comentários
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - Responder
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 7,915
