O que você precisa
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
5 outras pessoas executaram este guia.
2 comentários
Thanks for the easy to understand guide. Cheers!
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
