Ir para o conteúdo principal
Asus Zenbook UX31A Wi-Fi Card Replacement
O que você precisa
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 1 %32 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: passo 2, imagem 1 %32 Asus Zenbook UX31A Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Conclusão
Sherwin
Membro desde: 03/22/22
209 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 339
