Ir para o conteúdo principal
Asus Zenbook UX31A Motherboard Replacement
O que você precisa
  1. Asus Zenbook UX31A Motherboard Replacement, Battery: passo 1, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Motherboard Replacement: passo 3, imagem 1 %32
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Motherboard Replacement, Wi-Fi Card: passo 5, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement, Wi-Fi Card: passo 5, imagem 2 %32
  6. Asus Zenbook UX31A Motherboard Replacement: passo 6, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  7. Asus Zenbook UX31A Motherboard Replacement: passo 7, imagem 1 %32
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
  8. Asus Zenbook UX31A Motherboard Replacement, Fan: passo 8, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement, Fan: passo 8, imagem 2 %32
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  9. Asus Zenbook UX31A Motherboard Replacement: passo 9, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement: passo 9, imagem 2 %32 Asus Zenbook UX31A Motherboard Replacement: passo 9, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  10. Asus Zenbook UX31A Motherboard Replacement: passo 10, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement: passo 10, imagem 2 %32
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
  11. Asus Zenbook UX31A Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement, Motherboard: passo 11, imagem 2 %32 Asus Zenbook UX31A Motherboard Replacement, Motherboard: passo 11, imagem 3 %32
    • Disconnect the bundled connectors by pulling the cable away from the connector in the same direction that the individual wires are running.
    • Disconnect the ZIF connector by using the tip of the spudger tool or your fingernail to lift the locking tab. Then, gently pull the cable out.
  12. Asus Zenbook UX31A Motherboard Replacement: passo 12, imagem 1 %32
    • To disconnect the display connector, use the iFixit opening tool and pry the connector up and away from the board.
  13. Asus Zenbook UX31A Motherboard Replacement: passo 13, imagem 1 %32 Asus Zenbook UX31A Motherboard Replacement: passo 13, imagem 2 %32 Asus Zenbook UX31A Motherboard Replacement: passo 13, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws that hold the motherboard in place.
    • Use a Phillips #000 screwdriver to remove the single 4 mm screw.
  14. Asus Zenbook UX31A Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Brendan Walsh
Membro desde: 03/22/22
227 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 915
