Ir para o conteúdo principal
Asus Zenbook UX31A Daughterboard Replacement
O que você precisa
  1. Asus Zenbook UX31A Daughterboard Replacement, Battery: passo 1, imagem 1 %32 Asus Zenbook UX31A Daughterboard Replacement, Battery: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Daughterboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Daughterboard Replacement: passo 3, imagem 1 %32
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Daughterboard Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Daughterboard Replacement, Fan: passo 5, imagem 1 %32 Asus Zenbook UX31A Daughterboard Replacement, Fan: passo 5, imagem 2 %32
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Daughterboard Replacement: passo 6, imagem 1 %32 Asus Zenbook UX31A Daughterboard Replacement: passo 6, imagem 2 %32 Asus Zenbook UX31A Daughterboard Replacement: passo 6, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Daughterboard Replacement: passo 7, imagem 1 %32 Asus Zenbook UX31A Daughterboard Replacement: passo 7, imagem 2 %32
    • Disconnect the fan connector by puling on it horizontally until it disconnects.
    • Remove the fan.
  8. Asus Zenbook UX31A Daughterboard Replacement, Daughterboard: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to detach the cable from the board by pulling them gently toward the bottom edge of the board.
  9. Asus Zenbook UX31A Daughterboard Replacement: passo 9, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 6 mm screw that secures the daughterboard.
  10. Asus Zenbook UX31A Daughterboard Replacement: passo 10, imagem 1 %32
    • Remove by carefully lifting the board from the laptop.
Conclusão
Sherwin
Membro desde: 03/22/22
209 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 212
