Ir para o conteúdo principal
Asus Zenbook UX31A Battery Replacement
O que você precisa
  1. Asus Zenbook UX31A Battery Replacement, Battery: passo 1, imagem 1 %32 Asus Zenbook UX31A Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Battery Replacement: passo 3, imagem 1 %32
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop by lifting it up and out.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 1,032
