Ir para o conteúdo principal
Asus Zenbook UX303L Speaker Replacement
O que você precisa
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: passo 2, imagem 1 %32
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: passo 3, imagem 1 %32
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: passo 4, imagem 1 %32
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: passo 5, imagem 1 %32
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: passo 6, imagem 1 %32
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: passo 7, imagem 1 %32
    • Carefully peel away the defective speakers from the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Snow
Membro desde: 04/01/19
202 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G6, Harley Spring 2019 Membro de IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Membros
Autoria de 7 guias
Um comentário
Is the Asus UX303L same as U303L?
Michael Wolf - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 1,916
