Ir para o conteúdo principal
Asus Zenbook UX303L Cooling Fan Replacement
O que você precisa
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: passo 2, imagem 1 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 2, imagem 2 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 2, imagem 3 %32
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: passo 3, imagem 1 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 3, imagem 2 %32
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: passo 4, imagem 1 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 4, imagem 2 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 4, imagem 3 %32
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: passo 5, imagem 1 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 5, imagem 2 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 5, imagem 3 %32
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: passo 6, imagem 1 %32 Asus Zenbook UX303L Cooling Fan Replacement: passo 6, imagem 2 %32
    • Gently lift and slide the cooling fan out.
Conclusão
4 outras pessoas executaram este guia.
Equipe
3Comentários do guia
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Responder
I wish you guys had included the part number for the cooling fan.
mhyson - Responder
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 6,269
