Ir para o conteúdo principal
Asus ZenWatch 2 Motherboard Replacement
O que você precisa
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
  2. Asus ZenWatch 2 Motherboard Replacement: passo 2, imagem 1 %32 Asus ZenWatch 2 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
  3. Asus ZenWatch 2 Motherboard Replacement: passo 3, imagem 1 %32 Asus ZenWatch 2 Motherboard Replacement: passo 3, imagem 2 %32
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
  4. Asus ZenWatch 2 Motherboard Replacement: passo 4, imagem 1 %32 Asus ZenWatch 2 Motherboard Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pull up on the motherboard using tweezers to detach it from the watch.
Conclusão
Andrew
Membro desde: 02/20/17
314 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G1, Leahy Spring 2017 Membro de USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Membros
Autoria de 10 guias
6 comentários
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Responder
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Responder
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard -
Where can you purchase a replacement motherboard?
Tasha Kanahele - Responder
My zenfone wach 2 all function not showing please help me
Akhtar - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 2,695
