O que você precisa
Passo 1 Charging Port
Cuidado: as etapas de 1 a 6 são provenientes de um guia marcado como em andamento.
Use a thin plastic tool to peel the back cover of the phone off. Once the plastic tool has begun to pry the back off, slide the plastic tool around the edges of the phone to separate the adhesive holding the back on. Once all edges of the phone are disconnected, lift the back cover off.
Using the plastic spudger, pry up the vibration motor starting at the top right. The motor is held down with adhesive, so some force may be required.
Uma outra pessoa concluiu este guia.
