Ir para o conteúdo principal
Asus ZenFone 2 Laser Speaker Replacement
O que você precisa
  1. Asus ZenFone 2 Laser Speaker Replacement, Speaker: passo 1, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement, Speaker: passo 1, imagem 2 %32 Asus ZenFone 2 Laser Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Press and hold the power button until the menu appears with the option to power off.
    • If the power button is not working, proceed to step 2 and 3 to manually force shutdown the device.
  2. Asus ZenFone 2 Laser Speaker Replacement: passo 2, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 2, imagem 2 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 2, imagem 3 %32
    • On the lower right-hand side of the device, locate the notch and insert your finger nail to loosen the rear panel.
    • Continue to slide your finger around the seam to completely remove the rear cover.
  3. Asus ZenFone 2 Laser Speaker Replacement: passo 3, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 3, imagem 2 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 3, imagem 3 %32
    • Remove the sim card(s) and microSD card if installed.
    • Using your fingernail or spudger, remove the battery from the phone.
  4. Asus ZenFone 2 Laser Speaker Replacement: passo 4, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 4, imagem 2 %32
    • Unscrew and remove the ten 2.5mm Phillips #00 screws.
    • Unscrew and remove the two 5.5mm Phillips #00 screws.
  5. Asus ZenFone 2 Laser Speaker Replacement: passo 5, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 5, imagem 2 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 5, imagem 3 %32
    • Grab the lower portion of the frame and lift up to remove it.
    • If the gasket around the camera lens falls out, simply put it back around the camera.
  6. Asus ZenFone 2 Laser Speaker Replacement: passo 6, imagem 1 %32 Asus ZenFone 2 Laser Speaker Replacement: passo 6, imagem 2 %32
    • Use a spudger or other tool to gently lift up one side of the speaker. Continue lifting until the speaker is detached from the phone.
    • Ensure correct alignment of the speaker contacts to the pin on the circuit board.
Conclusão
Ang Heng
Membro desde: 01/17/22
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 359
